Storyboards
rook
I can't draw. I mean, really, I can't draw. It's so bad when I do storyboards I just look at the pictures and think-what the hell kind of movie is this gunna be?
And then I feel stupid.
There was a free storyboarding program floating around out there for a while.
Does anyone remember the name of it?
Thanks,
Rook
Check the Links forum below. There's a post "Great FREE Software" which includes a link to some storyboard stuff.
If the storyboards are just for you, it really doesn't matter how crap they are. Mine are nothing more than scribble, if I do them, which is rare. Some people prefer to have everything finely planned though, I prefer to only storyboard what is necessary - special effects shots and complex scenes.
In my last film, the only pick ups we had to get were from the only storyboarded scenes. I think it distracts me from what I am actually doing right there on set and what is being captured. I fine having the shots in my head is more fluid and adaptable, the crew probably hate me though!
lolfor Red Neck Samurai I created a A cmaera Shot list and a B camera List help shoot over 200 setups in 3 days. I was once comic book artist so i cant help but draw with hidetail each action so lets just say i had a long weekend of drawing lil boards.
I have been in the same situation as you with storyboards. My best work is when I actually sit down and plan out each shot, plus it makes my projects run much smoother. The problem with any of the storyboard software is that it normally is either pretty $ or that it does not do everything that you need it to do. I have played around with the trial of frame forge ($250+) and it actually works rather well. I believe this is what the people who did the hollywood DVD's planned most of theirs out with.
http://www.media-services.com/store/software_detail.aspx?iCategory=4&iProductCatalogID=248
There is a link for that.
There is also Storyboard Artist. I have never used this software, so I cannot comment on it's user interface or how well it works. It appears to use a similar moddeling base, plus has some interesting extras.
http://www.storyboardartist.com/artist.html
I just double checked, that is even more expensive, running about $300 for the scaled down version and $800 for the full version.
With both of these packages, they will not include all the visual clips you will need. This actually becomes a pretty big issue, because the idea behind storyboarding is to be able to previsualize everything.
A great example of this is with Hitchcock. I am currently reading a book about his 'Psycho' project and once he finished his storyboards he said, 'That's it, I'm done, now all that's left to do is capture it on film'. His production was the storyboarding. Simply brilliant.
Also, the book Directing Shot by Shot invests a lot of time into storyboarding, just to give you an idea of what an important step it is in the process.
The Incredibles DVD has a great extra section on storyboards also (Just FYI).
I hope this helps as far as the visual part though.
Have you ever played "hang man"? Remember drawing a stick figure? Draw stick figures and be done with it. You don't need anything fancy other than stick figures and camera angles or movements and placement of props. keep it simple. If you can't draw then draw like a child just to get the meaning across that everyone can understand.
I'm with stephenlnoe,
Another idea for better looking boards is to use action men and a digital camera. Have you tried video storyboarding too? That is far more helpful and gives you a better idea of the actual location, as well as lenses, movement, lighting etc.
mmm actually brings up a great idea. One of the things I am doing for an upcoming short film is filming all of our rehearsals. From that I dump the footage into Vegas and just do a crappy rough cut by doing lots of zooms and cropping of the footage to give me a general idea of what I want. It is far from the most professional of solutions, but to a certain extent it is easier and more cost effective than dropping the cash for a storyboard piece of software.
Then again, from my experience with Frame Forge, there are some incredible results that you can do. The problem is ultimately with the trial version and how limited you are with it. I am sure that the full version is going to be much more complete and offer a lot more to help make the work flow as smooth as possible.
Another way to storyboard, and this is not something I recommend, but it has worked for me is to go through the script, adjust your margins, and just write notes of what you want. I normally dump the script into Excel, and just paste the text, so each line has it's own cell. Then I duplicate the lines I want to get multiple shots of, and just write what shots I am going to get. This is a great tool to use to give to your PA or script supervisor also. They can go through and mark exactly what you have got, and what order they are in. It makes batch captures much easier, but more than that, you know what are your good takes and what is garbage.
Just a couple of suggestions from my experience.
