Sony UWP C1 adapted for other mics
GuyS
I have a Sony wireless transmitter that came with a lavalier microphone. The lavalier microphone terminates with a 3 conductor mini TRS tip. I would like to be able to make other microphones work with the transmitter.
It is my understanding that the Sony system is a balanced system. The receiver came with a male XLR (which plugs into my camera), to a 3 conductor mini (which plugs into the receiver). Sony tells me they do not have a cable that can be used with another mic. Sennheiser does make this type of cable for their systems, but I believe that the Sennheiser system is an unbalanced system.
As an example, I have a Sennheiser ME 66. I would like to "plug" it in to my Sony UWP-C1 transmitter. Has anyone been able to do this?
Ive done that - just get any old xlr to jack cable and plug it in. The difference with the ME66 is that it has a battery, so power is no problem.
But heres a question: If you wanted to wire up, say, an Audio Technica AT899 lav, would that work? Because somehow, you need to get power from the transmitter to the mic.
The ME66 + UWP-C1 combo is damn cool... I use it on run and gun quite a bit.
Problem is I have not found a female XLR to Male TRS cable. Where did you get yours timapter?
Can you tell me which pin in the XLR corresponds to which conductor on the TRS?
You can pretty much use any lav you want on that system, you just need to get it wired up for it. Any pro audio dealer that deals with that stuff should be able to do it. You can also have any cable you need made up for you at the same place. I'd call you local dealer and see if they can help you out.
-Dave
Ok a did a little more research. Lav mics are all condenser type mics. They need power. The Sennheiser ME 66 needs power as well therefore the XLR pins must correspond to the TRS rings. Now if only someone could advise me what pins get connected to what rings on the TRS plug. I can solder the connections my self.
Any cable for ME66
Any cable for ME66
Hi,
The ME66 is powered of its own AA battery - so dont worry about the cable. Ive been using a normal, mono, female XLR to jack that I had from an old vocal mic. I just attached a 1/4inch to 1/8inch adaptor to the end, and plugged into the UWP. No problems.
For wiring other mics to the UWP transmitter, just call your dealer that you got the sony from - they can all do it no problem. Im currently getting a custom adaptor built for my AT899 into the UWPs transmitter pack.
No worries.
Tim
thanks timapter
By the way how do you like the Sony wireless system. Can you compare it to others?
Um, the UWP-C1, is, I reckon, totally killer for its price, but it does have a few problems:
1. When batteries go low, the mic starts to hiss a bit with speech.
2. Crummy plastic casing not worthy of the electronics inside.
3. Big clunky supplied lav.
On the upside:
1. Battery life is quite good - I just change when the batteries drop to half way.
2. I made an elastic material case for my packs - it protects them, and lets me velcro the packs to mic belts I made.
3. The supplied lav actually sounds really great. Plus you can always just get another - I have the Audio Technica At899, and Im looking at getting a Countryman EMW.
I can only compare to the higher end camera mounted Sony systems, the Sennheiser G2 EW100 system, and the older Sennheiser rack mount evolution systems. I think the G2 is a similar system, maybe some people would say its a little better - but, like I said, the UWP system is very cool and works better than it looks.
