shooting vision2 200t or 500t
dasonras
Has anyone experimented with either of these two filmstocks? I plan to shoot a music video primarily outdoors (under sunny skies). I own a cannon 814 autozoom.
Will the 200t/500t run on my camera?
I am really satisfied with the impressive trailers kodak has of this film and i hope i can shoot with it.
You might be better off shooting with a slower speed film --- I've used both the 200t and 500t but for indoors. You would need a lot of ND so you can open up the stop because this is high speed film ... how bout the 100t or even 50d ? (that's the best film I've ever shot -- in my limited experience)
sorry for my ignorance. Where on kodak's page can i find 100t in super 8? Just so you know, this is my first stab at super 8 negative stocks. I've only shot tri-x in the past.
I don't think Kodak makes that particular stock in Super 8mm. You would have to order from Super8 Sound in Burbank. They cut all 35mm stocks and fit them into Super 8 cartridges.
For awhile, that was the only way you could get Super 8 negative, but then Kodak caught on and released the two Vision stocks themselves.
Where in MA are you from? Just curious since I live near Boston.
Anyhow, my friend is choosing between vision 2 200ISO and vision 1 320ISO for a short he's DP'ing. He really likes the look of vision 2. I think City of God may have used vision 2 stock...the Constant Gardner may have, too, or maybe it was fuji. They shot most of it in super 16 with an a minima and an sr3.
500ISO is definitely overkill if you're shooting outdoors. It's only for poorly lit indoors scenes, night exteriors, and creating a grainy look. I've seen a telecine of it and it's a beautiful stock with absurd amounts of exposure lattitude, but it's grainy, no two ways about it.
The 85b filter will eat a little light up, but unless you want to shoot at f22 you'll need to stack a gajillion ND filters with anything but ISO 50 or 100, I agree. But if you need to shoot anything later in the day or inside, you might want to consider using 100 ISO for flexibility. If your ultimate distribution method is video, I can't see the nominal resolution and grain differences between the two helping much.
I had no idea Kodak sold super 8 vision 2 negative. How much is it? I must buy some.
Why not try the new vision2 Daylight stocks? If you are shooting outdoors under sunny skyes, why get a tungsten stock?
If I was shooting super8 I'd go with slower stocks. ISO50, 64 or 100 will have a finer grain and be easier to use in bright exteriors (and for super8, grain alwayss tend to be too much).
Hey Policar... I'm up in Andover.... since your from MA, do you use Cinelab for processing? I've used them once before and everything came out great. I think they are the only large processing house in the area.
Anyways... confused about the vision2 daylight stocks. I know vision2 daylight is available in 16mm and 35mm, but i don't see it for super 8 on the kodak website. For the vision2 super8 line they highlight 200T and 500T.
Ah, maybe that's the problem... I really wouldn't know. It's almost impossible to shoot super8 in Brazil, unless you're MTV... :)
came out great!
came out great!
Hey... just to follow up on what i ended up doing:
I shot vision2 200T (7217), which is a negative filmstock. The image quality was outstanding. Looks like super 16.
With the built in 85 filter, the speed of the film drops down to about ISO125. Since it is a negative stock, the light lattitude is very good and in post it is very easy to plus/minus stops.
everyone should try this stock. You will be very happy.
I shot EASTMAN EXR 50D 7245 and it looked super clean and sharp on long lenses. Not so great on wide lens... with thats S16 for ya.
