Timmyjoe
I took a look at removing camera noise from my favorite Arriflex 16S camera.
Using a recorder that records in linear PCM (a "loss-less" audio format) I recorded the camera running with an internal 100 ft load and powered by one of Clive Tobin's TXM crystal sync motors ('cause what good is recording sound if the camera is not running crystal sync).
I wrapped the camera in a Barney that Lee at Custom Upholstery Products made for me last year.
I then used Bias SoundSoap 2 on a Mac to remove the camera noise.
This was just a quick test and with more time I would assume that the audio could be recorded better and the noise reduction could be finessed better.
The beginning of the take has the camera noise, "Four, mark . . . Arriflex 16S camera running in the background with a barney . . ." at which point I used the noise reduction software. The rest of the take has the SoundSoap 2 noise reduction.
It ain't perfect, but it shows the possibilities for sound sync work with an Arriflex 16S if it's barneyed and the sound is recorded loss-less, then sweetened.
Arriflex 16S sound reduction test
The file is a 276K Quicktime file so it takes a little bit of time to load and unfortunately it will not start playing until the whole clip is loaded, sorry. I compressed the audio clip with AAC, at 128 kbps.
-Tim
-Tim
