Senheisser lavs connected to DVX100A
samuelreich
Right now I have to Senheisser lav systems connected to my DVX100A. Two frequencies: 19.500 and 18.000. Otherwise the exact same settings.
The 19.500s sound fine. I can only hear the 18.000 if I turn levels all the way up. I have no idea why they would be softer than the other. Again, the sensitivity and audio out levels on the lavs are the same.
Testing further, I think it's the camera. When I plug into Channel 1 it's soft, when I plug into Channel 2 it's fine.
What setting on the camera could be effecting this?
- in the manual :-) that you need to read twice if you intend to ask questions and get answers , at least from me
Hey, that's not nice at all. I'm asking an earnest question.
Anyways, I found it in front of the camera. Thanks for the... half help...
On the front of the DVX there are two switches, one for each XLR input, labeled mic/line. I don't know what your output level setting is on your receiver but I'll assume that you want to select 'line' on the DVX.
If you have your receiver output set way low and are using the mic setting, there is a mic sensitivity setting for each input in the DVX menus (recording setup, I think) that could cause a difference. You really should be using line levels.
-Dan
