What I have in mind is that very contrasted text, like intense white over black background might cause flickering effect. I haven't experienced your problem, but this is teh first thing I'd check/change.
I'm guessing that you are using the scrolling text feature. This is when I noticed the flickering the most. I have found a few ways to get around this besides the de-interlacing filter, (which works sometimes too).
Create a Photoshop file with the text , export as TIFF, and bring it into 'Motion'. In you need to add motion (scroll, up, across, ect) do so and export as a DV50 file. The DV50 compression is much less severe than the DV compression and the resulting text will look much cleaner. You should be able to drop this straight into your sequence.
If this isn't for scrolling credits, but just some small words, you could import the photoshop layer and use that instead. FCP just stinks for small text, it doesn't render it well, especially in a DV environment.
