Samson H4
hmobley
Has anyone used one of these H4 recorders and could comment on if its a viable unit to maybe hook it up to my V1 as an external
Play with the settings and take really time to learn the machine to get the best out of it... it's now always in my audio bag connected to my fieldmixer for backup recording... use it even for recording live bands and the sound is simply GREAT!!!
I have tested the M-Audio & the Edirol R-09 before I decided to buy the H4. The reason to buy the H4 is not only because it's much cheaper but it has the best performances. Just plug an electric guitar directly into the 2 inputs on the bottom and start recording, or a mic... I just love the 2 XLR inputs... miss them on the other machines...
When you put the Zoom in your bag, give it some extra padding. Use an external battery, less stress to make worries or the zoom has enough gas to run... these days I just keep it running the entire shoot... when I need the backup for sound, I will grab it from the big WAV file... no hassle anymore to put it on or off to save batteries...
the H4 is certainly convenient but i couldn't seriously recommend it if it's going to be a primary recorder. a lot of ENG and documentary guys ask me what portable recorder to get, and if it has to be pocket sized, i will recommend the Korg MR-1 or Sony PCMD1. i have done comparison testing between all the pocket-sized recorders and i find these two to have the best sound quality.
the Korg has the most intuitive menu system i've seen in a recorder like this. i was really impressed how easy it was to scroll through options and change project settings on the fly. also its proprietary "1-Bit Recording" feature is interesting: by recording in this native file format, you can then re-interpret your audio data in any current - and future - bit rate and sample rate. so say you have a 24bit/192kHz session going in ProTools and you need to go grab some sound FX, but you want to use those sound FX later in a 24/48 session, just record them on the MR-1 at "1 Bit" and using their simple conversion software, send the data into any format for any purpose. there is no quality loss through the conversion, unless of course you're going to something low like 16/44. after doing a lot of research into how 1-Bit works, we determined its digital headroom is the equivalent to something around the 24/192 range, so natively, it's very high quality.
The Sony PCMD1 is extremely expensive but in my opinion has the best on-board X-Y mic, and overall, the best sound quality on the recordings i tested. that's a subjective thing of course, but i can say with confidence it's certainly an arm and a leg above a Zoom or MicroTrack or Edirol especially where the mic is concerned. i'm not sure if it's that much better than the Korg, i have yet to do some analysis between two recordings, but i would lean towards the PCMD1 in this test.
one thing that bears mentioning about the Zoom H4 is it is not a true 4 track recorder, which some people have unfortunately misunderstood. it can only record two tracks at a time, but you can overdub another two tracks to the same recording later on. also it does not provide "real" phantom power, we tested only about 20V on the XLR preamps, so it's too weak for a good condenser microphone. however, it's not exactly designed for high end microphones, so for simple plug-and-record scenarios it is a very easy and convenient machine. simply having XLR jacks IS a very nice perk. it's always a pain to have to hook up adapters or lead cables to the other recorders, which detracts from their portability.
