Render in RGB or YUV - difference ? MB probs
Carrington Benz
Hi,
I recently brought magic bullet for editors & since using the looksuites with the fcp widescreen matt plugin - I get these terrible pink lines on the edge of the matt.It only happens when I use certain plugins like blur or dip to color dissolve etc - I get a blob of pink appearing after I render - which is strange ?
Since this problem only occurs after I render - I was told that it could be something to do with the render space ie: YUV or RGB .
so I have tried the render in RGB space - which seems to get rid of it but I really want to know what the difference is - between RGB & YUV - in terms of quality etc ?
Has anyone else had this prob with the mb for editors & what is the difference between YUV & RGB.
To my eye - I think I noticed that the YUV seems a little richer in color.
Please help ?
I am still on FCP 4.1 & a G5 .1.8
Re: Render in RGB or YUV - difference ? MB probs
Native color space is YUV for FCP/Video. Many plugins for AE require RGB so there needs to be a conversion. In theory there's a slight loss in color resolution when converting but it shouldn't be too noticeable.
Hi ,
So - what is the advantage or dis-advantage of rendering in RGB ie: selecting " render in rgb " in the sequence settings ?
Thing is my pink line problem goes away when I select the " render in rgb" setting but I notice a color shift & lower contrast on the images.
So wondering if its not cool to render in RGB ? ???
I guess - Im asking if its ok to work in "render rgb" or is it a no no ?
cheers
See page 127 in FCP manual (just go to help to view pdf file)
From the manual:
Always Render in RGB: Forces codecs that normally process color using the YUV color
space to process using the RGB color space instead. If selected, this option may cause
subtle changes in color in your rendered material. If the video capture codec you’re using
doesn’t support YUV rendering, this option is unavailable.
Use this option if you want to accomplish a specific compositing task and you think color
clamping in the RGB color space might give you a preferred result over using the straight
YUV color space. For example, if you’re mixing After Effects filters, which only process in
RGB color space, with Final Cut Pro filters, which process in YUV color space, choosing this
option ensures a consistent look.
DV is YUV but you can render in RGB if needed. Msot effects programs deal with RGB.
Ok - im nearly there but - if YUV kinda looks richer or even "nicer" than RGB - is this possible or are my eye's playng games ???
I get that AE filters use RGB etc but does this mean that most peolple who use AE filters or this MB for editors etc can only work in RGB mode rather YUV?
If - FCP use's YUV space - then surley this means YUV must be the better option or space to stay in ?
Does this mean the only workaround - is to add the ae filters or MB filters to the raw footage without any FCP filters - then export uncompressed 8 bit - then import the file & start adding your Fcp filters ?? :'(
Last 'Q' is it genrally better to stay in YUV just for better image quality etc
I don't think the differences between YUV and RGB are that noticeable. Some slight color correction and saturation control will probably make a reasonable match. If you're going to AE or other program for effects then you probably want to cover as many there without bouncing back and forth too much. You can save in animation codec which does have some space savings but is still lossless. Avoid switching between in the middle of a shot (i.e. don't just go to AE for for a few seconds in middle of shot since you migth notice it) If you go out to DVD or film it will have to go through another conversion.
