Are you adding an audio transition or a video transition? I usually just cut out the stumble, maybe toss in a quick audio cross fade if need to smooth out the edit, and put b-roll on top to cover the edit.
The biggest thing, IMO, is to make sure it still sounds natural. If it sounds like the person's words have been cut up I just leave it as is.
Command+Option+T. Your best friend for hiding audio cuts. Set your default audio crossfade to 4 frames. Also, enable the audio waveform so you can visually see what you are cutting. Other great tools when editing talking heads are the ripple delete: Shift+Delete, and track selection tool: TTTT.
Finish your picture edit, export to OMF and do it in a DAW. Good tactic is to remove random ones, unless you can get a tighter cut, also if you cannot remove them, attenuate them.
