Recording diolouge in noisy forest (crickets)
Gang_Green
How do filmmakers record audio of diolouge in the forest without picking up excessive crickets and cadids chirping away. In the forests in Alabama; the sounds of these insects can be as lound as it would shooting down the street froma buisy hiway. So are there special boom mics that can be so selective as to kock out these sounds... or do we just have to shoot in the winter time?
Wouldn't those insects occur naturally in that envoirnment? Are you doing something that insects don't fit?
Typically there's so many humans around the crikets and such find another place to chirp. If they're really that close that they're interfering with your audio try sound blankets. Also I've heard a blast from an air horn will keep them quiet for a few minutes. I've always found that the genny and some guy talking to loud in the craft service tent is more of a problem then crikets.
I've heard of people shooting of a gun in the air to shut them up for a few minutes, but that means you have to have a gun, and that might not happen on location due to insurance issues.
Worst case scenario is you just record the dialogue as best you can, and get lots of wild recordings of the insects for your sound editorial department.
-Dave
Yeah, they suck. I don't know if the bang actually works, but if that does you don't need a gun... just bring a pack of firecrackers and light one before each scene.
I'll have to give that a try... I wonder what the neighbors would have thought when we were doing the zombie thing at 3am? BANG!
Well if your shooting a scene where the Director needs to give the actors instruction while the scene is being played out....how do you delete or erase the track that has the director's voice on it? Wouldn't this be the same sort of thing where you would be erasing out the noisy crickets?
Also I think using a good shotgun microphone and a good choice of windscreen (as there are many types for different situations) that could also help in getting better dialogue.
When I was out in Hawaii last year working on the show "LOST" they had a Sound Mixer right there on location and could mix out unwanted sounds or at least minimize them.
Make 'em work for you. Get a decent shotgun mic as close to your subject as possible. Record a minute of clean ambient sound (crickets) for use later in mixing. If you absolutely can't have crickets it's ADR time.
If you're planning on music, remember, it will mask a certain amount of low level "noise".
These are Alabama cadids for the most part that Im talking about; not crickets. So they are much lounder then you would imagie.
I was watching "LOST" the other day and wondering what they must use to get good audio in a tropical forest.
ADR is your friend. Don't be afraid of it. If there's not a lot of "acting", you can probably get away with using "bad" actors. Just record lots of background sounds and tromping through the forest you can edit in the background later.
Forests are also bad because you can hear the crew walking as well.
You can also try lavs, but I suspect you'll still hear the cadids.
