recording analog to digital
pixel
Using a SonyDCR-TRV460 camera, I'm trying to convert old hi8 tapes to digital. The camera's connected by firewire to FCP 4.5. The video plays fine in log & capture, bt no time code appears & I can't log & capture. Sony tells me the camera may not be compatible with FCP.
In an unrelated (maybe) problem, I can't use the headphones connected to the camera because of static. The sound works thru the camera's speaker. The camera is set to DV Out. Never had this problem with any other camera.
Thanks!
Re: recording analog to digital
I once tried converting Hi8 tapes, through a Digital8 camera, with horrendous results. If I remember correctly, the only way was to capture through analog.
You can do this with most decks, or with an analog break-out box.
hope that helps.
-CJ
www.arkhamfilms.com
Thank you so much! The Sony camera cost me $400 and I still have time to return it. You're great!
I've used Digital 8 camera fine with capturing Hi8 videos through firewire but don't think true timecode is supported in Hi8 so you'll probably just have to capture straight and use scene detection or use iMovie.
In my experience, the footage ended up being choppy. Might have been the setup, or the camera in that instance. If it worked for Scottdvx100, then it was an isolated event for me.
It sounds like it's working fine through the log/capture window for you.
Go to capture settings on the Log Capture window (Cmd + 8) > Device Control > Select Uncontrollable Device.
You won't get any timecode, but it should work fine for editing.
Sorry for the confusion.
-CJ
i have also captured analog hi8 thru a digital8 camera into fcp. no probs. and no timecode. just set log and capture to "non-controllable device" and then click "capture now" and hit play on the deck.
Thanks!
Next problem - When I click "capture now", the black screen comes up saying "allocating disk space", then nothing happens. When I hit play on the camera, the spinning beachball starts & I have to force quit. What am I doing wrong?
Try setting prefs to max capture a smaller amount. (30 minute default?)
Do you have plenty of disk space available?
Is this on the same drive as you system?
Is this on the same drive as you system?[/quote]
I reset max capture to 10 min, but sill get the beachball. I'm using FCP on an external hard drive with 133 GB available.
Also, I did try hitting "play" both before and after hitting capture now. This has really got me stumped, and I appreciate you folks helping!
Do you have enough internal disk drive space to record a bit?
Worth seeing if this works better.
you mentioned having 133gb drive, but does you no good if you dont point FCP to it as a scratch capture...just a thought.
Thanks -
Scratch disk setup is fine. Plenty of internal disk drive space. Still scratchiing my head.
