Need robot walking sound effect
rocketguy2
I need a heavy, metallic, clunking sound effect for our retro-robot walking around. Has anyone found something like this?
Thanks,
Gary
Build it up by layering multiple elements.
For example:
Hit an empty oil drum (or metal gas can) for a boomy metallic sound.
Smack an anvil with a rock for some metal-on-stone bite.
Use the bottom of an iron frying pan to crush a walnut and pitch it down two or three semi-tones if the robot is heavy enough to crush the pavement.
Use a the groan of a backhoe's hydraulics for leg movement.
Find an old dot-matrix printer, and use the whine of the print head shuttling back and forth (but not printing) for some extra servo articulation.
If the robot's feet still don't sound massive enough, try adding the reverb tail of an explosion or pile-driver hit to each step.
http://freesound.iua.upf.edu/
Go there, sign up, look for robot, eletric motor, etc. They should have it.
or go here:
http://www.findsounds.com/
They have a lot of great stuff as well.
Building your own stuff is fine if you have great mics, a good sound space to record and such, but since most people don't, you can find a lot of base sounds at either of those sites and mix them as well.
This article explains how the sound of RoboCop was done.​
http://hollywoodlostandfound.net/sound/robocop/
