Peter C.
I'm thinking of replacing my 1920x1080 monitor with a larger higher resolution. I've noticed that when using a 4k monitor, if viewed at it's native resolution everything is too small and you need to reduce the resolution, scaling things up which takes processing power and makes it look soft. On the mac that means cutting the resolution in half as a good compromise. My question is if this is the case why not buy a 2k monitor that way you'll be viewing it at it's native resolution. So what size and resolution monitor do you use?
