I've been reading a lot about lav mics lately but nothing really answered what I wanted to know....do you use lav mics with a shotgun mic? Do they produce better sound...if you have a shotgun mic is it recommended you get a lav mic as well?
You can use lav mics for a number of things. They do not necessary have to go with shotgun mics, but you can do it. However, I believe if you use both at the same time you can sometimes screw up the frequency the lav mic runs on ( I think its the frequency). Other than that you can hide lavs in plants or near an actor for wide shots (wide enough a boom mic is not usable). On one shoot I worked on, there were two actors that were walking down the street. The camera was locked down and they started far away and just walked to the camera. The sound guy put lav's on the two actors and when they go far enough into range they switched over to a boom mic and then it started a tracking shot. I remember they had to cut the lav signal on a break in the dialogue and switch to the boom mic (which had a shotgun) when the camera started to dolly. I hope this helped, although you should wait for Barry S or someone else to go into more depth or clear up any mistakes I made.
A boomed mic should usually be your first choice and will produce the most natural sound--a good mix of dialogue and ambient noise. However, as Tyler mentioned, there are situations that make it impossible (a wide shot) or difficult (a tight space) to boom the talent. Maybe it's a one-man show and you don't have a boom operator. If you're shooting a documentary, following the subject around with a boom can be pretty obtrusive.
A good wired lavalier would be the next choice. A lavalier can be easily hidden in the talent's clothes or unobtrusively planted on the set. Compared to boomed mics, lavaliers tend to have a flat sound, but you can add some dimension in post by mixing in some ambient sound and adding a touch of reverb. When it's difficult to use a cabled mic, a high quality wireless set can be invaluable. Maybe the talent (or subject) is roaming all over a location and you're shooting long takes. Sometimes you're just tired and don't want to hassle with a cable. :
When a recording situation gets tricky, using both a boomed mic and a lavalier can provide you with insurance. It could be the way a scene is blocked makes booming possible but easy to mess up. The lav track can save your butt in post if you have to fill in some holes.
Here's a general order of preference for recording in dramatic films.
--Boom with natural sounding cardioid mic.
--Boom with a shotgun.
--Wired lavalier.
--Wireless lavalier.
--When things get tricky, record with both a boomed mic and a lav for insurance.
I find Lavs have a lot of additional uses. In car scenes where the gun is hard to get into the car and pointing it the wrong direction can pickup vibration from the car chasis, I sometimes conceal a lav behind the rear view mirror between two people exchanging dialog. Same goes with tight tete a tete scene, a lav in a plant is a nice alternative to the boom if done properly.
One overlooked microphone which I am in love with is the PZM. They need to be mounted on a hard surface, but I have mounted them to plexi-glass and then swung them over a scene on a boom arm attached to a junior arm and gotten some very full sound. This is especially important if you don't have the desire / budget / time to revoice and throw yourself on the mercy of an ADR session, as I assume most DVX100a users will want to avoid.
The problem with a shotgun and a lav in the same scene if edited together is that they can cause a situation called inversion (or more properly, phase cancellation). What this means is that since the microphones are different distances, the get sound at slightly different times from each other. Two audio waves in sync increase the power when added together. Two waves inverted cancel each other out. The result is that the two audio sources may interfere with each other in editing, and a lot of work to meld them together.
In reality, this is only a problem with live broadcasting, since the issue can be fixed when encountered in post. I like having a gun over my people, a lav in the bushes, and a PZM on the floor or ceiling getting a wide spectrum of stuff. I will also often run around with a simple 635 nd microphone and a CD recorder and pick up wild track from different parts of the location -- you never know when it will be useful.
ok but say if I put a lav mic on an actors clothing...wouldn't he movement of the clothing make a bunch of scratching and loud sounds..or do lav mics eliminate those sounds?
also is it better to have a cardioid mic before you get a normal boom mic? I mean I don't wanna buy a boom mic if its better to get a cardiold mic.
the rusling is a common problem with lavs , there is no one way to solv the problem ,every worderob have its ups and downs ,for ways to find the right way you need some expirience in lav hiding ,and some time more then one lav to choose from, there are more then one method tape the lav to shirts, bodey, hear miking and others,
if you can place the mike outside ,its alwais can be better then ber it under the clothes , there are another problems esspesially with women , braslets and neckless , earigs which make noice ,
and we didnt talk about sweating problems and wind problems .
do a good search google s rec arts movies .production.sound .that issiu and handreds of technics to place alittle ****, had been discused aalot of times
for your second qwestion -you dont shoot with one lence ,and if you do you are going tothe middium long one , thats trew with mikes as well start with good short shotgun (depends on your pesos )and add aditional after
for regular work one good shotgun and one hippercardioid is the way to start
No, you are correct -- clothing rustling is the evil hell you will be sentenced to if you choose to use a lavaliere. It is a hateful, horrible, nightmarish cycle of death, you try to fix it and you think you've got it, and then it happens again, so you call "cut" and you go fiddle with it for five more minutes, trying to carefully position the mic, trying to make "footballs" out of gaffer's tape to tape it down, trying to pull the clothing out of the way of the mic, and you try again, and the dreaded rustle happens again...
... and you wonder why you didn't just boom the shot in the first place...
there is no such a thing perfect world and sometimes the lavs is the only way to go (2 camera shot and thats end of your boom )
when you shooting outside and there is alot of urbanic or any other noice which covers the rustling ,it works and saves your day , and like i sad -you need to be expirince to place it right (thats why they pay me )
there is no black and white only shadouse of gray soif you are going to buy lavs buy them in different colors it can make your live easier ,
boom its about 50-70 % in films that i was envolved ,sometimes you have to go with lavs otherwise you will be without the job
Barry,film that i did few months ago is going to Venice festval
Promise land hotel -by Amos Gitay
80% of useful sound was recorded with lavs
sometimes 4 at ones
(it was shoot with dvx100 pal uprez to hd to 35 arrilaser)
Were you involved? Kipur's sound kicks ass. Also I like the sound in that one that is steadycammed through a low class apartment, what's it called, Alilla? Anyway, I love his work, and for him to be shooting with a DVX is a great testimonial on this cameras. Have you worked on his films before? If you did, nice job.
... An israeli feature going to venice... Damn, it's going to take a long time to get here...
So if you abig fan of the sound in kipur thanks ALEX Klod , maibe the best sound disigner in ISRAEL (JUST FOR YOUR KNOULEG , THE DIALOG WAS COMLITLY **** SINECe IT WAS ALMOST NOT IMPOSIBLE TO RECORD IT WITH ALL THE TANKS AND HELLICOPTERS AROUND( i heard the rushes in editing room) , it was recorde by Eli Yarkony ,the only israelly soundmixer that have best sound for tv drama in US (Golda),
about israelly films in festivals , we had few in Kan (we have it almost every year), and i had my sound there( Late MARIAGE) and in BERLIN (AVANIM), Its not so hard ,its only politics and bad taste of the jury , sory i prefer US B moovie in day show
Amos worked with dvx becouse the budget and the way the moovie was shot , Idont think he would back to that again in near feature , but since iam shooting documentary with him next week on dvx ,everything possible ,
for those who ask how i record it , straight to the camera with ZAXCOM digital wierless that worth more then the camera
I see a lot of israelli films in first class festivals, I know there are a lot of good things coming that way and I also know there are a lot of shitty films in those as well, especially considering our brazilian representatives...
I was just complaining it is going to take a long time for the movie to get here in brazil, so I'll have to wait to see this DVX feature by myself...
I recently saw this Israelli documentary called Checkpoint (Forgot the name in hebraic) massahim? something like that... It was pretty impressive, very high quality, strong piece. absolutely amazing.
'Mahsomim" ,i sow the moovie ,its exellent , thats one of the best one man band that i sow for years (was shoot with pd-150)
which israelly cinema movie did you see?
Alex Klod -sometimes has klog too
