Is there a way to copy/paste an effect across multiple comps/images?
andrew00
Hey,
I'm creating a video from a series of still images, the idea will be to travel through them over time in w/the 3d cam. As the camera passes each image, I want them to fade away, and I've been doing a shatter to do this. I've actually been using this tutorial - http://ae.tutsplus.com/tutorials/vfx/design-a-breathtaking-body-shatter-effect/
I've got it working for one of the images, so hurrah for that. However, my question is = is there a way to apply the shattering to each of the images, aka so they each shatter. If I can 'copy/paste' this effect then it'll save me having to manually do it for each image, which'll be a big time saver, esp as I'm not the best at this.
If there isn't a way I'll have to do it manually which'll take a lot of repetitive time!
In the above tutorial there's a lot of comping/precomping so there's essentially multiple layers of stuff going on you see, so it's not a case of just copying the one effect, there's the tree of stuff going on.
Thanks!
If you did not figure this out yet you can click on the effect and the click animation, save preset. Save it to a user defined folder in your animation and presets and then you have an effect you can use over and over. Give it a distinct name so you can recognize it.
