"Insufficient Content for edit"
Bill Clar
I get this error when I try to add a dissolve transition to an edit point. The clips are 4 seconds in length each and I've left the length of the transition at one second.
So what gives? I can apply this transition easily to lesson files that accompany "Final Cut Express HD", but not my own.
Kevin, thanks for the help but I must confess that I'm a little lost.
kwoff said:
Are there any frames beyond your in and out points where the clips join? You need those "handles" to do a cross-dissolve. (You can apply a fade without them.)
Kevin
I'm not certain what qualifies as two clips 'joining'. I did however try adding a dissolve to the original clips with no in/out points. Still no luck. I can't do a fade either.
Bill
Meaning where the cut points connect.
If there is no footage that extends past a cut point in either direction you will not be able to apply a dissovle.
Hope that helps.
Now I get it.
The default option for a dissolve shows one second past the out point and one second before the in point. That's where my problem lies.
To correct this, I need to adjust my in/out points, or adjust the dissolve settings to one second before the in point and one second after the out point.
Thanks everyone!
Bill
