Importing JPG's as Single Frames??
agentjonny
have a prob...i've exported some footage as single images to run into photoshop for some stuff, but i can't figure out how to import them back in as single frames, it seems like it's making each image 1 second long when i drag the folder into the timeline..i need to figure out how to import images as single frames...anybody??
Two ways...
First...
Change the still image import preference to 1 frame... I forget which preference it is but you'll find it. You'll need to remove the ones you've imported already and do it again.
OR
Load them all into the viewer and then select them all and control-click and change length to 1 frame.
Good luck,
CaptM
You'll find it under User Preference > Editing > Still/Freeze Duration.
Set it to 00:00:00:01 (1 frame duration)
If you've already got the clips in the time line at 1 second, change the duration to 1 frame or delete them and bring them back in after you've set the frame duration in the User Preferences.
