Pascal Parvex
utahmoviemaker said:But I am a PC person! And the cost of the MAC is going to run hundreds right? I already have 6 PC's in the house! (all networked, etc.). Is there not a PC alternative?
There are a lot of alternatives on PC. It depends on your PC's. You should use the best of the bunch. What is the best you have? Maybe you have on that has a FireWire conection included, but you have never used it. A FireWire card with a cable won't cost you more than maybe 30 to 40 bucks. And editing...the problem is, you need a software that is able to handle the 24p of the DVX. But you can use any editing software and, with the right setup on your camera, F5, the your result will still be very filmlike. Hope that helps.
And Macs are easy to use, but PC's compete very well, as the're not so expensive. For example, if you wan't to upgrade your RAM on a Mac, then you have to increase your mortgage if you don't know where to get it cheap (same quality of course).
