How to output for 16:9 tv sets?
fritz
Can anyone describe for me how to go about cropping/zooming or whatever it is you have to do to create a genuine 16:9 output in FCP (4.5) from 4:3 footage? I know, you'll probably ask why I'm not shooting squeeze mode, but the thing is, I want to produce a DVD with three different options: 4:3 and letterboxed for people with 4:3 tvs and 16:9 for people with 16:9 tvs. My understanding is that I can do this by shooting full frame (4:3) and applying the widescreen matte, and then cropping and zooming or something like that. I found these instructions online (at http://www.helerab.fi/widescreen/):
"1 Duplicate your 4:3 Sequence.
2 In the duplicate Sequence, apply the Widescreen filter with a 1.78:1 (same as 16:9) ratio to all clips.
(You can skip this if you want - it'll only help you zoom the frame in step 5 and it will probably increase rendering time)
3 Make a new Sequence, and make sure "Anamorphic 16:9" is checked.
4 Drop the duplicated 4:3 sequence in the new 16:9 sequence.
5 Zoom the [matted] 4:3 frame to fill the 16:9 picture area (you can just drag the handles in the corners).
[If you have the time and want to get advanced, you'll do this on individual clips to crop out only unwanted stuff - not just zoom in straight on the centre.]
6 Render out the sequence before printing to video.
Remember, Final Cut will seem to "letterbox" the 16:9 sequence in your Final Cut Canvas (the window where you view your edited stuff).
This happens if the Canvas is in the shape of 4:3 (which it often is in the standard window layouts).
But the picture really is anamorphic - you can test this by hooking up a 4:3 video monitor (the picture is horisontally squeezed) or by printing to video and displaying the picture on a 16:9 set."
I get stuck at setp 5 - how do you do this zoom? I can't see any dragable handles! Am I nuts? Well, maybe I am, but still! Can anyone help?
Hit the "W" key to turn on the wireframe. You'll see a blue box with a white X going surrounding your clip. You might want to resize your viewer down to 50% or so, so that you can get a really good look at it. Grab any corner of the wireframe and resize. If you hit the "Shift" key you'll be able to acually change the dimensions of the clip. You probably don't want to do that. By simply dragging from any corner of the wireframe you'll be able to resize the clip +/- . You can then grab the point at the center of the wireframe "X" and recenter your clip as desired.
I've never done what your attempting. Zooming in on the footage might degrade it slightly, but at any rate that's how you do it.
Hey, it worked! I now have a genuine 16:9 clip with no masking!! I haven't output to DVD yet and checked it on a 16:9 tv, but I have an external (4:3) monitor hooked up to my computer and it is squeezing the image, which I'm taking as a good sign.
Thanks again for your help!
ZaniacMedia is correct, you will degrade the image a little, but it will not be noticeable on a TV. (I haven't checked on a projector, but I assume that the bigger the image gets, the more likely you'll notice the degradation.)
To add to the suggestion, once in the 16:9 Sequence, under the motion tab, in basic motion, set the scale (or is it size), anyway it is the first option, to 133.33%. Then you dont have to worry about moving the footage around, or if you have properly scaled it to fit the sequence.
And YES, the squeezing of your image is a good thing. it means it is reading it as 16:9, but your monitor cannot display it at the correct ratio. To do that you would need to create a DVD and have the DVD player display it at the correct ratio. (Which will create the black bars on the top and the bottom.)
Thanks for that tip waltind! I'll give it a try - it certainly would be easier than dragging the wireframe, as I'm not 100% sure that I've zoomed it the correct amount. It would be nice to have some precision there.
I know that I'll lose some resolution, but I can't think of any other way to provide both 4:3 footage (with and without letterboxing), and 16:9 footage that will play properly no matter what tv you use.
Another question just occurred to me: does anyone know if the loss of resolution from zooming in on a 4:3 image to create a 16:9 image in FCP would be greater, less, or equivalent to what you would get if you shot with the squeeze mode in camera (since this only uses the middle section of the CCDs anyway)?
Using squeeze, or scaling within FCP you'll get about the same loss in quality. Doing it in post will give you more options as you can reframe the image. If you're wanting little to no loss in quality you'll want PhotoZomm Pro. Checkout the sticky on Uprezzing 4:3 to 16:9 for more details on that.
Thanks again Ryan! I'll certainly give Photozoom Pro a try for anything I shoot which is reasonably short. I've checked out that sticky and it sounds amazing.
Sorry guys, but what sticky are you talking about? (is it in fcp forum, couldn't find) I was reading Disjecta's website about using Photozoom Pro on Premier, I wanted to know if you get the same result with FCP?
Thanks for your help.
Joe
