How to make mono tracks stereo in Soundtrack Pro?
The 300+ Quicktime mov files I captured (24p advanced) from my DVX100A all have two separate mono audio tracks, rather than one stereo one.
When i edit the audio for any of these files in Soundtrack Pro, only one of the two tracks is changed; the other remains as it was, because I can't even access it in Soundtrack. If I try the "Convert to stereo" command in Soundtrack, it creates a third mono file and the resulting sound is high-amplitude static which is unuseable.
If I modify my clips in FCP to join the mono tracks into a stereo pair, when I then open the clips as multitrack projects in Soundtrack to edit them, they open as mono track Quicktime files, and I'm back where I began.
Any idea how I can convert my separate mono tracks in my 300+ Quicktime movie files to stereo tracks? Thanks so much for your help.
I think you can "link" them together inside of FCP. It's "Create stereo mix" or something similar. I'll look around...
I have only had probs with the opposite: making a stereo track into two mono ones.
-a
What I have done in the past is export the track to Soundtrack Pro, make my adjustments and corrections then save it, go back to FCP and duplicate the now single track to the audio channel just below it. Then select both clips and under Modify, make them a Stereo Pair (I believe the keyboard shortcut is Option+L)
You may have to adjust the level again after you've turned them into a stereo pair.
