mvb
DVXuser Sponsor
DVFilm Maker can convert an Apple DVCPROHD quicktime to Raylight AVI without recompression. It does this by simply copying the frame data from one format to another. Then from the resulting Raylight AVI the Raylight "P2 Maker" application can make a P2 card image which is playable on the camera.
The detailed steps are:
1. Export a DVCPROHD quicktime from FCP
2. On a Windows workstation, install the demo versions of DVFilm Maker for Windows (version 2.3h) and DVFilm Raylight (version 2.01). Configure the Raylight output folder to an empty folder on your media hard drive (see the Raylight tutorial at dvfilm.com/help).
2. Open the DVCPROHD Quicktime exported from FCP in DVFilm Maker. Maker will not be able to play it back (or will play it back with a white screen) but just ignore that. In Maker select "Deinterlace" and then unselect "Deinterlace", to turn off all 24P and other processing.
3. In the advanced options select "User selects compression." All other advanced options should be OFF. Click OK to close the advanced options window.
4. Click on Start. You will be prompted for the AVI codec. Choose DVFilm RAYLIGHT. Click OK.
5. When the process is finished, you will see the movie in the AVI playback window. The AVI viewer in Maker does not play back sound. Use File->SaveAs to save the AVI with an appropriate name. You can check the AVI with Windows Media player, and control the playback quality with the Raylight control panel (see the Raylight tutorial).
6. Start Raylight P2 Maker and drag the AVI into the P2 Maker window. See the instructions in the Raylight tutorial on using P2 Maker. The P2 Card images are stored in the "P2Cards" subfolder in the Raylight output folder. P2 Maker can also write directly to a P2 card.
