HELP! Unrender: fixing a big mistake
poya
I captured tens of hours from my dvx100(set to 24pa)... some of it captured at 29.97 and some at 23.98, I don't know why. To deal with this, I edited the whole project in a 23.98 sequence and rendered the 29.97 portions.
Now I'm trying to backtrack. I'm going to recapture the 23.98 portions in 29.97 in a 29.97 sequence.
So does anyone have any idea how I can avoid recapturing the parts that were originally in 29.97, but which were rendered in a 23.98 sequence? Is there any way to unrender back to the original quality of those 29.97 clips so I don't have to recapture them?
Thank you so much for your help.
If you just need to ditch the render files, highlight all those clips and press option b, and then press it again. That will quickly do it inside FCP. Otherwise, track down your render file folder and delete the contents. Again back to old. Or, just drop the stuff onto a new sequence, FCP won't remember that it's rendered the materials before. Good luck.
cheers.
We did copy the whole thing into a new sequence (29.97). The whole thing appears as unrendered then. It seems FCP does recognize that these files have been rendered....
Is it a wise idea to render them again in 29.97, or are we causing further decline in quality?
I'm worried because there are horizontal lines appearing over any area where there is motion....
The horizontal lines when there is a lot of motion: that's interlacing. That's what interlacing looks like on a computer monitor. Play the video back to an external monitor and the problem should not be there (preferable a broadcast monitor, but hell a TV set or LCD monitor can do the job as long as you're not CC'n).
As for the 23.98 footage, I would re-digitize it at as 29.97 right away, if that is your long term plan. The longer you wait and the further your proceed with things with it at 23.98, the more headaches you're likely to endure down the line. Redigitze it, re-edit whatever needs to be re-edited, and then you can proceed to locking picture and going to online/finishing. Good luck.
cheers.
