Help--Buzzing on an Azden shotgun mike
Jackaroe
I am using an Azden SGM 1X shotgun mike and have lately been getting a buzzing (feedback) sound. I don't know much about audio. When I touch the XLR cable at the point that it connects to the microphone the buzzing stops. Sounds like a grounding problem but I don't know how to fix it without keeping my hand on the XLR cable.
Any suggestions?
I am using a DVX 100A camera.
Thanks.
Since microphones are balanced (differential) sources, an open conductor on either the non-inverting or inverting line can cause the CMRR (common mode rejection ratio) to drop to nearly zero. The result could be high levels of ripple (hum) components in the audio signal. It is equally possible the microphone is fine and the cable could have the intermittent open. I would suggest a substitution test; either a different cable with the same mic or a different mic with the same cable. That should give you a fairly conclusive determination as to the cause
try a different cable. if that doesn't work, then try a different mic, if you can. if that doesn't work, you may be getting a grounding issue in your camera. How are you powering your camera?
-Dave
I have tried a different cable and I still got buzzing. Sometimes it would happen and sometimes it didn't.
Unfortunately I don't have another mike to try.
"Since microphones are balanced (differential) sources, an open conductor on either the non-inverting or inverting line can cause the CMRR (common mode rejection ratio) to drop to nearly zero. The result could be high levels of ripple (hum) components in the audio signal. It is equally possible the microphone is fine and the cable could have the intermittent open. I would suggest a substitution test; either a different cable with the same mic or a different mic with the same cable. That should give you a fairly conclusive determination as to the cause"
Sorry, but I am new to this and a lot of what is quoted above is unclear to me. So I changed to a different cable and still got the buzz which "should give me a fairly conclusive determination as to the cause" which I guess that conclusion would be that the mike is bad???? Is there no solution to this except to buy a new microphone???
I was powering the camera with the cable that goes into the wall outlet. Is there a way to ground the camera to stop the buzzing??
..use a battery on the cam and see if it makes a difference.. also are you using phantom power or the aaa battery in the mic? try switching that as well. if you switch to battery .. shut off the phantom power.
"Sorry, but I am new to this and a lot of what is quoted above is unclear to me. So I changed to a different cable and still got the buzz which "should give me a fairly conclusive determination as to the cause" which I guess that conclusion would be that the mike is bad???? Is there no solution to this except to buy a new microphone???"
If you have access to another camera or microphone preamplifier (mixer) then try your microphone on the other device. If you still encounter the problem, then it is highly probable that the mic is the cause of the problem. Grounding issues (unless there is a connection from the mic body to another ground point) are highly unlikely in this configuration as there is no real path for a ground loop.
i am having a buzz sound occur while using either xlr input 1 or 2 on the dvx100b. i am using a condenser mic that is phantom powered, i have tried two cords and two mics, all with the same results (a nasty little buzzing sound) - i am battery powered.
khmuser, i hope to meet you when i come out to the TTN shoot in L.A. -- any suggestions here anyone? help is greatly appreciated!
-kyle
Is the camera connected to anything that is plugged in? Have you tried it at different locations? Does the buzzing stay consistent? Have you tried different headphones? Have you tried recording the buzzing; is it on the track when you import into your NLE?
If you get through all of those with no change then your camera's circuits are most likely the culprit.
