When moving video files from hard drive to hard drive, is there eventually going to be a lose of quality or some degree of information lost throughout transfering several times?
In a word, no. There is no qualitative loss in a digital copy like one would expect from an analog copy. There is of course the possibility of an error (though highly unlikely), but no degradation from the copying process itself.
Thats what i figured. The reason i asked was that i copied a rendered file to an external drive and then copied from the external to my laptop. My laptop is brand new (athlon 64 4000+, 1Gram) and when i play the file, its a bit jittery about every 5 sec. , same with the audio. Is there somthing i should change on my video card? thanks for the speedy response.
If it is "jerky" on the laptop, it may be that the processing power requirements for playback are taxing its capabilities. Often, despite the impressive hardware used, laptops can have reduced performance (often intentional to reduce power consumption). Do you know the bandwidth requirements of the rendered file (data rate / time)?
Since the laptop seems pretty beefy, it seems likely that your laptop's hard disk is too slow (although that's not really possible if you're just playing DV encoded video). The playback rate has very little to do with your video card, and absolutely nothing to do with how many times you copy the file.
Does it play smoothly from an external drive connected to the same laptop? That'll help you narrow down the source of the problem.
