Ground Noise / Hum filters?
I've recently began noticing a lot of "hum" in my editing setup. I'm looking for some good filters to run some of my gear through. I've used ground loop isolators from Radio Shack in the past and they work ok. Wondering if there are better options.
I have everything hooked up to a TrippLite voltage regulator with noise filter but I'm still getting some humming.
Thanks...
I would first check to see if the ground on your ac power is good. it is hard to speculate not knowing what you have connected, but try disconnecting or starting from scratch and see if you can isolate which piece of gear is the culprit . Because if your ground is solid the you are looming or something like that.
Make sure you don't have any of the audio cables running close to monitors. I've even had speaker cables pick up noise from being too close to a monitor. Other than that you may have a ground loop. There are usually two grounding systems in audio gear. The chassis ground is what gets tied to the main power lines. And you should be careful about disabling that. It sounds like you used a ground lifter but if you used that before the power strip all you did was remove the ground from your system - not a good idea. If your trying to break a mains ground loop you need to use the lifters on one or more pieces of equipment, but at least one needs to be grounded. Your trying to break the loop not eliminate the ground.
But there is also the audio ground and on a lot of equipment that is not tied to the chassis ground. That can also have ground loops. And you could have just the opposite problem, a bad connection or a bad cable.
After a quick check to see if lifting the ground fixed the problem I would go straight to connectors and pots, switches etc and clean and exercise them. That's the problem 90% of the time.
The quickest and dirtiest fix is the exercise everything. Plug and un plug all the connectors a bunch of times. Toggle all the audio switches a bunch of times and slide all the sliders and twist all the knobs. The ones that hardly ever get moved are the most likely to get oxidization on them and become noisy. If you want to go whole hog you can get some DeOxit from Craig labs and clean all your contacts. If you listen while exercising you will probably hear the switch or knob thats causing the problem. If you have the speakers on (low) and you find a scratchy pot keep exercising it till it sounds smooth again (if after 30-50 cycles it hasn't cleaned up you may need to have it repaired).
Good luck
