Good DIY set up for voice over recording?
mixer28
Hi Folks
I am trying to get a strong sound recording for a voice over for video and recording it at home (so not in a studio environment) - I am after the best results I can get and wondered if folks had any tips.
I will use a me64 cardoid mike. But do I need to dampen surroundings and try deaden the acoustics to get best results? Or would you say I can just place mike with 30-40cm away record as best as I can and then make any improvements to the sound in software (like audition) afterwards?
Any advice most welcome
It really all depends on the sound you're after. Narration and voiceover are typically recorded in a very accoustically dry environment, so most rooms will require significant dampenning before they sound like a vocal booth. Record a mic test in the room you have in mind, and see if the result is suitably.
As for improving the recording in Audition, try to record your VO in such a way that it requires minimal proccessing (subtle EQ adjustment and compression). If you're finding yourself reaching for a noise removal plugin or corrective EQ, then you have to rethink your recording space and equipment setup.
The ME64 is probably not your best choice for studio vocals, since it just won't give you that smooth and articulate sound typical of professional VO. Search through some of the old posts on this forum for large-diaphragm condensor mic reccomendations for voiceover. You'll also need a decent microphone preamplifier, if your recorder doesn't already have a solid one built-in. If you're recording directly into a camera or an inexpensive audio interface (anything on up to an mBox2 pro), you're recordings will benefit greatly from even an inexpensive mic pre like an ART TubePre, especially if you're using a large-diaphragm condensor.
I mentioned somewhere else a radio trick. Sit on your bed and toss a blanket over yourself. You can get that very close VO sound. You look silly and you'll need a flashlight if you need to read anything, but it is a trick that has been used a lot by producers on NPR and such. It does work and is very cheap. Of course your bed room has to be pretty quiet and you'll have a hard time convincing "talent" to work this way, but if it's just you...
thanks both of you - great info.
I tried the blanket option out and your right it really does have an effect.
Getting good posture and standing up would be nice though :-) Is the only other alternatiive to build some kind of make shift sound booth out of blankets? I have some backdrop stands that might do it - but is having a blanket over the top the critical part to stop sound bouncing off the ceiling?
I have been recording straight into a zoom h4... not sure of the preamp implications - it has gain settings so does amplify signal.
I also recently ordered an Oktava 012 - though I get the impression it is not the right mike for VO. Have strtaed looking into the large-diaphragm condensor mics - Rode NT1A seems to be an affordable entry level solution - any idea if it is any good?
Thanks again for the advice!
The ceiling is the least of your worries, unless it's particularly low. Hardwood floors and walls are the real issue. A few backdrop stands and makeshift curtain/blanket rods will do the trick nicely. If you have a few C-stands lying around, you have it made.
efksound said:
Nice one.
We sometimes use a large spare piece of cheap accoustic foam (2x2 meters) and "wrap" it around the speaker.
I have no picture of it, but we take two lighting stands, fix the 2x2 between them and than form an U-Shape with the foam, let the speaker stand inside and than almost close the U-shape... Mic hangs from overhead...
very guerilla but sounds good...
The portabooth is of course more handy;o)
efksound said:
I emailed the company that makes that box a few months ago, they are like in Sweden or something. They were not able to direct me to a place to get that exact box in the US. If anyone can find a retailer for the US, let us know.
A foamcore box, like Spotted Eagle demonstrates, would work just as well but not nearly as portable.
Cheers
