Final Draft woes... lost outline
limehouse
I lost an outline trying to save in Final Draft. I hit "save as" over my last saved copy, and it gave me some kind of runtime error, then shut down. Then I found that the file was missing altogether from its folder.
Argggg... I don't want to lose this file! I have a backup, but I'll lose some important stuff.
Anyone know a way to search for the file, or where it may be saved? Thanks!!
I had that happen a few times while using Final Draft.
I jumped ship and went with Movie Magic Screenwriter instead...
I never looked back.
:beer:
I think it's okay as long as I don't save over a previous file, which means I have to use a different name on each save. I generally do this anyway (not tonight for some reason :( ), but I still don't like the idea that it'll erase things.
Final Draft makes a back up regularly by default. You should have the back up copy to go to. Check around the ol' hard drive and see if you can find it...
You should always back up your scripts weekly on disk... Most you can miss is a weeks work - Better then all.
I usually back everything up like crazy, but this time I was lazy because stuff was hitting me so fast and I wanted to get it down. Learned my lesson on that one.... even though I got it all redone :)
I love Final Draft and will never jump ship. Sure, it has a few bugs, but I can deal with them as long as you are constantly saving. The interface is so easy to use.
