FCP HD problem - need urgent help!
sunseril
I have been editing a 30 min project on FCP HD. I've captured 160 GB worth of tape, broke it down into smaller clips and began to lay the clips down onto the timeline. So far, I didn't notice a problem. I then added some Live Type titles and effects, and still no problem. I imported 5 jpeg photos and placed them on the timeline, then using the motion tab, I created panning and zooming effects on these photos.
Here's where the trouble begins:
I then played back the timeline and when I watched the canvas, it was a nightmare: the audio is fine, but the video is stuttering and out of sync, it feels like it's playing back at the wrong frame rate, I'm not sure. It looks like it is skipping frames IN ADDITION to being in slow motion.
I tried to adjust the RT settings, but to no avail. It have 1 Gig of RAM, so it should be enough.
I copied the Jpegs, pasted them on a new sequence and then deleted them from my main sequence, to see if this could be the problem. No change. I tried playing back the clips in the Viewer, and even the clips which had not been brought down onto the timeline, now play back out of sync, skipping frames, slow motion, etc - but the audio is great. It's weird.
I played back the clips in Quicktime and FCP 3, both on the same computer, and the clips are fine. It seems to only be a problem with FCP HD.
I'm so confused though because I have been using FCP HD for one month, with the same footage in question now, and have had no problems. I tried even to open up a new project and imported one of the (now) problematic clips and it still played back poorly.
I've run out of ideas. Has anyone seen this happen before or have any suggestions on how to fix it? Thanks - it's really urgent and the entire project looks unusable right now.
Re: FCP HD problem - need urgent help!
Stupid question, but have you rendered? What color line is above your jpegs?
CaptM
