Exporting to MPEG-2?
I was told that I could export my projects to MPEG-2 right out of FCP. However I do not see that as an option. I do see MPEG-4 listed though. So if I can come out of FCP HD to MPEG-2 how is it done? I know I can use compressor to go to MPEG-2 but I was told I could export to MPEG-2 and then import that file into DVDSP for DVD authoring.
Yeah, All you have to do is go file>export>Quicktime Converstion. Under there you can you to video options or setting and in there MPEG 2. It will let you tell it the bite rate you want and one or two pass VBR all that stuff. Make shure that you have the audio box checked so it will do both.
Export using Compressor. You can controll just about everything from there. Plus if you are going right to DVD Studio Pro, it's ready to go! ON my dual 1.8 G5 it takes not very long at all going that route.
Joe
ok when the save box opens up at the bottom you see quicktime movie. and then options right next to it. ok click on where it says quicktime movie and change that to mpeg 2 then use your options to change the mpeg 2 settings. hope this helps
Do what JoeFowler said. Create your mpeg2 in compressor. You want your files to mpeg2's for dvd as mpeg4 isn't a universal codec.
If you are creating 24p material do as Grame Nattress says in his tutorial: Export a self contained quicktime(master copy). then import that into compressor, which will automatically flag it as 24fps.
IMG I am still not seeing MPEG-2 listed as an option when I do it that way. I am just going to have to export to Compressor then on to DVDSP. I was told that I could right from FCP HD to DVDSP without having to encode in Compressor (using DVDSP to do the encoding). Of the 2 MPEG's, MPEG-4 is the one that shows up in the list when I click on Quicktime conversion. I tried the other one (Quicktime Movie) and didnt notice it there either.
Also what can I do about interlaced lines that show up after Compression that are not seen before compression? When I imported my last batch of footage into DVDSP3 all my footage had those ugly fuzzy lines everytime there was some motion or I paused playback. In Compressor I selected a DEInterlace filter, I am wondering if I should have left that box unchecked.
Don't quote me on this, but I think that the mpeg2 is set up for ntsc tvs. On your computer screen you'll get the jittery movement on bodies, but once you burn it and play in a dvd player it should be fine.
Dvx shootet that is strange. I went to export something just to make shure I wasn't lying to you. I useally compress everthing with compressor. Just export the mpeg with compressor and then when you go into dvdsp just go file>import>Assests and chose you mpeg version. Then drop it on a track and bild and burn. DVDSP will reconize that it is already and mpeg stream of video and it will not compress or I think they call it encode. It will still have to mux and build everything but you will not encode the video.
As for the lines. Stabb might be right but I have never noticed it in any of my work. Try it see if that works Check your bit rate. and do a two pass VBR. Best motion see if that helps. another thing I do. Is I had a 5min promo I wanted to look really good on dvd so I used a 7.0 to 7.5 KB on it. and when I did that in compressor and took it into dvdsp and went build/format it kicked me out and said bitrate was to high. So I went in to DVDsp pref. and changed the encode bit rate in there. Exported out an uncompressed quicktime out of FCP and just let DVDsp encode it and had no probs.So that was strange I thought. But anyway doing it one way or another will not save you anytime it will take you about the same I would just try to stick with compressor
Well if you export using compressor, make a copy of the 60min high quality preset (assuming your footage is under 60min) and change the settings to 24p. It should make your footage a 24p .m2v file that will allow you to make a progressive scan DVD in DVD Studio Pro.
I brought the footage back in FCP and then exported everything to compressor with no problems. I am not sure why I couldn't go from FCP straight to DVDSP but its all good now. For this particular DVD, I won't be doing a 24P DVD because not all of the videos were shot in 24PA.
to see mpeg 2 in final cut options in exporting you need to have dvd studio pro install, i had this problem and i install dvd studio pro and got the mpeg 2 options. And for compression, at work we did a bit rate calculator. It helps to fit everything on a dvd.
max
JoeFowler, how long does it take your dual g5 to output an hour video to Qtime? My dual g5 takes about an hour. Just got it, doesn't seem like it is working very hard but takes along time.
