ENG-44 field portable Audio Mixer opinions?
there are few things missing on that one
good monitor section
preamp attenuation
output attenuation
pick mitering
input limitters
12 v phantom power
no ms decoding
oh yes it have xlr out instead PL FOR HEADPHONES :-)
might be more relevant to psc dv mix or rolls
quit hard to reinvent the weal so you reinvent the price :-)
OK i got a telephone from a friend who actually bought one for his small camera rig and he asked me to check and configure what is the best way to work with , he is running sony z-1 and was need for some cheap solution to work normally with at 4073 and a couple of g-2 he own .
so this is from quick impression in the shop
its a very light mixer what is good , quit average building
the preamps are quit clean ( i did a test with my schoeps ,line outs to my sd 302 ) but ......
there is no attunuation of any kind so it distort it on high picks , you need at least 20 db to work normally with 4073 or 10-15 for the schoeps
the high pass have a very hard curve that starts around 200 hz so in some way the 4073 started sounds as me 66 :-) and my schoeps become a neuman 185:-)
the pots are easy to drive but not so comfortable as on wendt .
the potentiometers sits directly on the schaccy so it will be very fast to change one if they will come dirty
the phantom power appears on line ins ,what might be very dangerous
( grate to run condensers on gunshots:-)) if you connect unbalance equip to the line ins
the mixer has fixed limiter which kicks around +6-8 dbu , it works well - but - it alwais there , the same **** as the psc dv mix
the tone generator doesn't have fixed point ,it sits before master fader - dont like that but you can live with .
no matrix for the headphones - very , very bad
the headphone amp have enouth gain and work quit well
so summary - with extra 200$ of work or external hardware you can bring this mixer to normal operating - you can place used 48 ph psc power supply in front which has attunuation and hi pass filters ( that would make wonders to mixer battery life) or make another attunuation circuit and place it inside the mixer with extra switch for your prime mic
the monitoring could be done with external box or another circuit inside .
I'm waiting to see if i can get schemes from sign video to make a switch on the limiter , if so it can make the mixer work as normal device( at least for me) .
so summary - yes and no - they could make it better , it might work ( not for me ) , if it does worth 750$( with phantom box and headphone matrix) i cant tell you , every one will make their privet decision
