editing systems?
naughtygeorge
I recently purchased a dvx100b.. I own an Imac 20' 2ghz 1gb ram and noticed that exporting a short clip I shot takes a long time 35 minutes or so...using Final Cut Pro is this normal?
It depends. What format were you exporting as? And how many effects, CC, etc did you do on the video? Lots of transitions? If there's a lot of stuff to render, or you're exporting to a good quality format, or even both, then render times can go up immensly.
exporting as quicktime movie, no effects, no transitions just some stock video.. I used "quicktime compression" when I export as "quicktime" It's only a couple mins...?
is my system good enough to edit video?
Good call twocik23.
Depends what they are......applications such as photoshop can be really heavy on your memory so things will work a bit slower than normal. Try exporting the same clip without anything else running.
