Edge feather separate sides?
One thing that has always annoyed me is that when you crop and feather things in FCP you have to feather ALL sides. Is there another way? Lets say I want to do a split screen and feather the middle but not the top and bottom etc.
Thanks,
- Jarek
In the Matte folder (in video filters), you can use either a four-point or eight-point garbage matte, and you can then add the "mask feather" filter which allows you to feather just the edges of that matte.
You can place the matte wherever you want in your frame. Usually you'd want to duplicate your video clip to V2 and add the matte to V2, if say, your clip is on V1.
experiment to get different effects.
hope this helps.
Richard
Yeah I suppose there's that. There's also the Edge wipe transition trick and leave the tranition setting on the same percentage for beginning and end, it all just seems so tedius for something that should be easier.
