DVD Burning???URGENT!!!
UncleBenji1977
I recently burned a DVD video for a church in my area and it ended up having really bad syncing. It looked like a Kurosawa film with bad acting. Anyway, I burned the DVD on Pinnacle's authoring software. My question is, is this a bad way to burn DVD's? I've also tried Sony's DVD Architect. I love it's interface but the DVD's came out a little discolored. So, do you think that my authoring software is the issue? What's the best out there? I need help because I need this done pretty soon. Thanks!
Pinnacle Impression? Owwwww. Trash. Evil. I learned that the hard and expensive way.
I've never had a problem with DVD Architect. Did you color-correct on an NTSC monitor? If not, it may not be surprising that what you see on a TV is not the same as what you see in your NLE preview window.
The color problem is only seen on the finished DVD...And i'm seeing both the NLE version and the DVD version on the same monitor. I wish I could describe what it looks like. Maybe my copy of Achitect is poop.
Check your settings in Architect. Possible compression issues. Is the program removing pull down on 24P? If using the same monitor to view it's obviously not a calibration deal so check carefully what the software is doing to video file...
