DAT RECORDERS?
  • Start date Start date
G
Guest
Guest
Audio is something i know very little about. How is the sound quality with the DVX? I was considering the use of a DAT recorder. My previous movie experience is with 8mm and 16mm film (so i've always used a DAT). Is it worth using a DAT?
Re: DAT RECORDERS?
The DVX is better than other prosumer cameras, and may be comparable to a less-expensive DAT, but a high-end dedicated DAT would probably deliver better audio than the DVX.
Re: DAT RECORDERS?
The last gig that the producer insist on dvx ended whith tones of dropouts on sound 9 and this is not the thirst time thats happen), there is no way to know actual recording and monitor after pb sound (no confidence heads)
if you are running very expencive project run back up dat or hd disk drive directly thrue the fierwre ,.the analog and atod stage is good enouth but the recording system could be very painfull after
Re: DAT RECORDERS?
If you are looking to buy, don't even waste your money on a DAT machine. The DAT manufacturers are no longer making new dat machines, and no longer support them, so getting support on a dat machine is not going to happen. You should go with some sort of non-linear hard disk or flash recorder. You can get the Marantz PMD-670 for $699. Sound Devices 722 for $2375, or the 744t for $3950. Edirol has a new machine coming out called the R4 that will be under $2K.
-Dave
Re: DAT RECORDERS?
The biggest difference between DAT and DVX100 is sample rate 44 vs 48. Really what is more important is how you capture it. You'd be better off spending money on a good mic and experienced sound man then the recorder.
Re: DAT RECORDERS?
Both DAT and DVX sample at 48Khz. The difference is going to be in the quality of the pre-amps and all the circuitry involved. The DVX is the best of the bunch as far as prosumer cameras go, but high-quality dedicated audio recording equipment should be better still.
