Cut in Premiere then convert to MPEG2 24P in Vegas
  • Start date Start date
G
Guest
Guest
I seem to be having problems with the quality of my 24P DVD MPEG2 footage from Vegas.
I've followed the exact workflow requirements layed out by Sony in their pdf instructions (http://mediasoftware.sonypictures.com/support/productinfo/24p.pdf) on the subject with only one additional step they didnt mention. I originally captured and cut my project at 60i with a 60i timeline in Premiere.
I shot in 24pa mode and since the camera outputs 60i video not to mention Vegas and Premiere only CAPTURE in 29.97fps I figured I could export my final cut in Premiere into Vegas as a AVI at 29.97pfs and Vegas wouldnt know the difference between that file and if I had captured the uncut footage in Vegas in the first had.
Once again I followed all the other offically layed out steps exactly and after I converted the footage to MPEG2 with the proper 24p DV DVD Architect template and DVD Architect didnt have to recompress it but never the less my video had a degraded look that was both more choppy and a bit lower res.
Need some help. Any ideas?
BTW my total bitrate including audio was at about 8,800,000.
-Brett
Re: Cut in Premiere then convert to MPEG2 24P in V
Just a shot in the dark here, but... since Premiere doesn't understand or support the 2-3-3-2 pulldown for 24pA, then maybe once you rendered your project, it became a standard 60i project and you lost the ability to remove the 24pA pulldown. I think one of the most important steps was to capture while removing the pulldown on the fly. Just a guess though.
See reply in Premiere thread.
