CRT monitor jitter w/ heater!
malmsteen
Hey all,
I have a G5 with dual CRT monitors, 21" Sony Trinitrons, and a PC with one 19" Sony Trinitron monitor in my basement, so 3 monitors in total.
However, my room is right beside the room where the heater is, and whenever the heater goes on, my monitor starts jittering. It jitters the most when the heater just starts running, and after it runs for about 10 seconds, it still jitters but not really noticeable. It happens with all my monitors, so it's not a monitor problem, I suspect it's more of a power distribution issue, so I went out and bought a high quality surge protector, but it still doesn't help.
It was OK when I had the computer on the 2nd floor, but I had to move them down because I got my G5 and had no room for it.
First off, the jitter is annoying, and I'm more worried about my system/hard drive getting busted.
Does anyone know why this is happening? any solution? would buying a UPS help? Please help!
What is happening is the electromagnetic field from the central heating unit, and I bet its an electric heater, not a gas one, is large enough that your monitors are within that field.
Before I retired from the IT biz, I had clients who got this a lot. They'd put stereo speakers (unshielded) next to monitor, phones, etc. You have to move the monitors away from that electromagnetic field. A UPS nor anything else short of a large, thick sheet of lead will help.
I won't do any damage right off the bat. But long term use will greatly shorten the life span of your monitors. I've never seen that sort of thing mess up a hard drive or any other computer component in real life, but in theory, it could with really long term use.
Get your stuff further away from the heating unit until you see absolutly NO effect on your monitors under any situation at all.
To see this effect, I used to take the reciever of peoples phones, or a small magnet, and wave it around in front of their monitor so they could see the colors distort.
Hey thanks for your opinion.
However, we use GAS heater, not an electric one, and I'm sure of it.
I'm pretty sure it's the amount of power that suddenly increases with the heater, that's why I thought surge protector would fix this problem, but it didn't.
Would UPS do a better job in regualting power throughout my basement?
Just by reading the spec on the box, it's protection is poorer than surge protector, it only backs up power.
I appreciate your help.
Power coming through your AC cord does NOT cause the monitor problems you discribe, period. Even gas heaters have heavy duty electrical circutry. You can put all the UPS on it you want, the problem won't go away.
UPS units just have better surge protection circutry than those power strip surge protectors. They have to in order to keep the battery from blowing up from a surge, which is a REAL danger if they didn't. I've seen very expensive surge protectors (not UPS units) fail in electric storms, and phones, answering machines, computers, etc, blow out a LOT with simple surge protectors.
I have dang near 20 years of professional It experience to back this up. But, think and do what you want...
