Converting 4:3 to 16:9
molocono
I shot footage in the 4:3 aspect ratio that eventually ended up on KPBS. They wanted the footage in 16:9 so I had to find a way to convert it. I talked to an editor and he described the following procedure:
1) Create a 16:9 project
2) Cut and paste my 4:3 project into the new project
3) Adjust the 'Aspect' settings on all the footage in the new project. Had to change the Aspect setting to -33.3
The footage still looked squished but I decided to turn it in anyway. I figured I couldnt do anything else. So I get an email today from KPBS and they said that they had to have an edit session to convert my footage to ACTUAL 16:9. My process did not convert the footage to real 16:9, they said it looked squished. So can anyone tell me what KPBS did or what other things I could've done to convert my footage? Thanks!
What you'll want to do is adjust the scale of the image.. this will degrade the quality - but it will look better than something thats "squished."
You will probably be better leaving the "aspect" setting alone. Scale until the black lines on the sides are gone.
So did I take the correct steps by creating a 16:9 project and pasting my original project into that? Basically, I would need to modify "step 3"?
You could have simply masked it with a 16:9 matte, which can most of the time get the job done.
