I'm looking to capture VHs footage. I have it set to 29.97 which seems to be correct, but i'm not sure if the filed dominence shuld be upper, lower, or none. I would appreciate any help, as well as any other suggestions for capturing VHS.
Don't change any of those options. If you haven't already modified them, don't do it now. You shouldn't need to change the field dominance. I understand you have the ability to do so, but don't, leave it alone.
Suggestions for capping VHS. Hook up the VCR, run the video and audio out into a firewire capable digital camcorder that allows A/V in. Then connect the firewire cable from the camera to the computer. When logging with Final Cut Pro, Avid, Premiere, or whichever app you use, make sure that you have it set as a non-controllable device. Thats basically the easiest way to do it and the details vary depending on which editing platform you use.
