C-Stand mic boom
tigeba
As I have recently acquired a pile of heavy mics, I have been considering new mic stands to replace my cheapies. The really swank audio boom stands tend to run hundreds of dollars.
I was wondering if anyone has seen a boom arm for a C-Stand that has threads for a mic clip. It seems like something that should exist, and if it can hold a 1K fresnel, it can probably hold a microphone. Any ideas?
you can go to any mechnic that can make you short arm with tread for your mic holder on its end .
and that one goes inside the boom arm roter head .
dont forget the sand bags :-)
A good many of the audio operators I work with carry one of these to hold their boom for longer sit-down interviews. Works well and fits standard grip heads off-the-shelf.
The star nut comes off the base of the 3/8 or 1/2 threaded rod. That's the end that'll go into the c-stand grip. These are between $4 and $12 depending on what model you buy at places like Billy Bob's Bass Pro Fishing World Shops.
e
http://images.outdoorinteractive.net/mgen/264196_d.jpg
the grip department at filmtools.com is one of my favorite places to find misc. stuff that i use for sound but is traditionally grip equipment.
i have used two things for holding a boom pole, not just because i'm lazy but i can't see having someone stand there holding a boom for a scene where the dialog is all stationery.
this is the least expensive one and the one i got first...
http://www.bhphotovideo.com/c/product/277230-REG/General_Brand_REMBOMAST_Boom_Pole_Holder.html
this one is a little bit better because it holds the boom farther apart so it should be less stress on the boom pole...more important if you have a nice k-tek carbon pole vs. an aluminum one.
http://www.bhphotovideo.com/c/product/277231-REG/BoomMate_BPH_Microphone_Boom_Pole.html
k-tek makes a REALLY nice one, i haven't been able to justify spending that much on a boom holder yet...
http://www.bhphotovideo.com/c/product/292924-REG/K_Tek_KBC_K_BC_Boom_Pole_Cradle.html
i use these items on a standard C-Stand with a boom pole...you can get a boom pole as simple as one of the gitzo boom poles (carbon or aluminum) and then the shockmount.
but don't forget, you need a grip head to hold the boom holder to the c-stand and you need a shockmount to hold the mic on the end of the boom pole.
matthew
