Burn an FCP project dvd with no menus?
evolvnyc
Having only idvd and FCP5, is there any way to burn a dvd that just plays and then stops without having to have any sort of "theme" or "menu" on it? Help?
If iDVD is anything like DVD Studio Pro, you have to set a "First Play." If you set your "first play" to the track you want to use, rather than setting it to the menu, it will work.
if you open up idvd and then go to "map," you can drag your film file direcly into the first window and it will auto play as soon as you put it into the dvd player.
