Building your own sound booth
toddburch
Hi all,
Had this idea to build my own "sound recording booth" out of wood and then line it on the inside with some sort of acoustically absorbent foam.
Has anyone done this before? If so, do you have any suggestions/pointers/tips?
Thanks,
Todd
Re: Building your own sound booth
I think one good way to find out how good ur space is , is to record in a studio for a minute or so. Then just keep building your space until it sounds as good. I did this and found my closet with tons of clothes and a think mattress sounded just as good, but i had a good mic like a schoeps hypercardiod which sounds great and is directional enough to sound neutral.
Oooh this is a big subject, but a FUN ONE!! ;D
Ok, so you're just building an isolation booth and not a monitoring room - that's even more fun, but still...
You're going to want to do a bit more than what you mentioned. Magdi's advice has merrit, but it also assumes that you've tuned your monitoring room, which you probably haven't. Anyway, we first need to define your available space and requirements. So...
1) Is this going in a basement in a home you own, or in an apartment where you rent? In other words how much construction can you do?
2) Are you going to be recording one or two individuals doing voice overs and ADRs or are you recording singers and instrumentalists? Bands? If so, what kind of music?
3) Will the booth exist within your greater studio/monitoring environment or adjacent to it?
4) What is your budget (roughly)?
5) (This is the big one) Will you be happy building a booth that provides a good recording environment but leaks sound, or do you actually require a "soundproof room"?
There is a ton of information about this type of stuff on the net, but I'm sure we can point you in the right direction. I'll be traveling for the holiday but will have my laptop with me and will check in on this thread.
Best,
Matt
If you want to save money, you can research and build one yourself. But if you want to save time, Markertek offers some prefab kits for not too much dough, like $600 or so.
I seem to remember the name WhisperRoom from the NAB convention also. I think they were in the realm of $2k, but they were slick.
Whisper Room is great - and they're pretty soundproof, which is why they're expensive. Many horn players I know use them as practice rooms in their apartments. But a recording booth does not have to be soundproof necessarily, it just has to provide the necessary acoustics to record as desired - usually quite flat.
The Markertek on the other hand is not they way I would go. Hell you get the same basic effect with some 2x4s and some sound blankets for WAAY less money. For what those are costing you could build a very nice iso booth as part of a home studio.
Matt
MattC, I could almost picture you rubbing your hands together like an evil genius when you read the first post.
I'll cop to the evil part. The genius part might be a stretch.
I've actually stayed awake just to see if Todd responds. I'm sick... I'm going to bed...
Hold me...
Matt
Sorry I didn't respond earlier, had to go to bed (crazy job...)
Anyway, I guess I should've clarified that I just want the isolation booth, a whole studio isn't feasible (I'm in an apartment).
So yes, I'm just looking for something I can build (budget $100 or so) that will provide a good recording environment by removing reverb, etc. The mic at my disposal is a Sennheiser 416, and the use will be essentially for ADR and VO recording.
-Todd
I'm in the process of building a sound booth now. Matt is right, monitoring will tell you a lot about what your booth ACTUALLY sounds like. My monitoring room is in my house, it's small but it's well tuned and I know the room well so I know where the trouble spots are and I know what level to monitor at to get an acurate sound picture.
For my booth I'm building it out of Owens Corning 703 (rigid fiberglass panels) and baltic birch frames with ply backs and a pourous fabric over the spinglass. I am making six panels which are 2'(w) x 7'(h) x 4"thick. Those panels are then joined together and removable and one panel has a clear plexiglass windon in it. It's basically a big room screen that forms a semi-circle.
This booth is NOT built to be soundproof. And honestly, you don't need it to be if you follow a few basic principals.
If you have problems with unwanted sound leaking into your booth, say from street noise, then move the booth further away from the offending sound source. For example: I have a street in front of my house that can get noisey during the day. So I moved the booth's location further back, further AWAY from the street noise. Every time you double the distance from a sound source you decrease the volume of that source by 6db. So let's say your booth is five feet from a HVAC vent and that vent is making noise in your audio. Well, move the booth TEN feet from the vent, and see what that does. Also, remember that unwanted sound is only "sound" relative to the volume of the sound you want to capture. It's called the "noise floor." If the sound you WANT to capture is louder, you won't be able to hear the unwanted sound beneath it. Then you simply delete the parts in between sound events you want to remove that unwanted sound and replace them with room tone that doesn't contain the unwanted sound.
For example: turn off your HVAC for a while and record 5-10 mins of the room with NO sound at all. When you delete sound between the sound events, say dialog, you drop that empty room tone in there so it's natural and doesn't go COMPLETELY silent between each scentence.
I'm just about to run out the door, so I'll respond in detail later tonight.
Todd, you just took all the fun out of this. ;)
Kidding. The first thing I would do is to see if there was a closet I could convert. If not, hanging moving blankets (home depot) might be your cheapest, most portable/breakdownable bet. Stay away from foam that isn't purpose built for this. Auralex makes great stuff and it works, but most foam (especially that egg crate crap that everyone loves to use) isn't all that effective and it's a fire hazard. You can build a folding 3 or 4 wall unit with plywood and hinges that can stow under your bed. Either cover the panels with Auralex or use rockwool/moving blankets.
A closet would be better.
There's my ride, I'll chat later.
Matt
I used to use thick blankets and sourrounded me with it. It was cheap,fast and did the job. Yes, building one would be really nice.
Gossamer hit it on the head, no reason to add anything.
Bluespider - that certainly works and works well, the only downside is convienience. I find the moving blankets sold at Home Depot work really well. They absorb sound like no tomorrow (at least as far as blankets go).
Matt
