Best Way Of Creating A Still Image And Adding Movement W/o Flicker
just recently a friend of mine recommended that any still image i import into final cut from photoshop should be saved as a .PNG with no interlace and no square pixels... i tried this, and they seem to look very good... even when i add motion to them from side to side...
HOWEVER... my problem lies when i want to take that still image and add movement to it going towards and away from the screen... i got a jitter... a flicker... whatever you wanna call it... it's shaky and it's frustrating..
i've tried the flicker filters, de-interlacing... nothing works... does anyone have any good recommendations for this??
thanks...
I had this problem for a long time too man. What you do is open a new photoshop file but make sure you select a new file that has the dimensions 720 x 540 and I like to bump the resolution to atleast 200. Bring your image into this window and then export it as a .png and reinport it into FCP and movement should be alot cleaner.
