Beachtek question
RichW
I have a Sony DVX2000 and a new Beachtek DXA-6vu. The Sony lets me choose either 12 bit or 16bit mode. The 16 bit is much preferable in quality. But with 16 bit you cannot adjust the balance with the Audio Mix control. Is that a problem, or does the Beachtek now allow me to overcome it? I.e, is that sound still going to be adjustable in post?
It is getting quite confusing. The camera and the Beachtek can each be set for mono or stereo. So, if I am using a single mono shotgun mike, what is best? And what if I am using two mikes?
Clearly the mike level s/b set on manual, not automatic, and I should use headphones to monitor. Would one want to set the Beachtek levels for each track and leave them, or switch them up and down during recording depending on which person is talking?
3 questions, (or more)! Thanks for your help.
