audio and video import
storyp24
When importing files from the HVX 200 the audio and video are in separate folders. How do I import them together in order to place in a timeline? thanks
If you're using broadcast you don't have to worry about the seperate folders. In the tools icon there is a p2 tool that will open the main folder and show you the clips. you can then import the ones you want directly to the timeline if you want. Canopus takes care of keeping the audio and video files together. It's easy and fast.
Yep, if you use tools ---> p2 select, you can import the clips straight from the card, or from a location on your hardrive that you have offloaded p2 clips too. If you do a direct import, it will be pretty much instananeous, and you will be able to begin working with the clips (audio and all) right away.
Jason
As the others have said, import using the P2 SELECT utility.
Make sure you point it to the folder above the CONTENTS folder, and not to the CONTENTS folder or anything below it.
That will ensure it grabs all the appropriate metadata and reassembles all the separate pieces into a logical clip.
Brandon
