AT 4073a hollow sound?
RichW
I was told on another forum that the AT 4073a mike can have a hollow sound when used on the camera shoe. Anyone have experience with this? Any suggestions (beyond taking the mike off the shoe)? thanks
Maybe indoors... but that's it.
I'm sure what they meant is that you won't get a really FULL sound out of any mic unless it's at a normal distance from the subject's mouth... ideally as close as 2' or so... and certainly not more then 5-6' away. The main reason that cam-mounting a mic is a bad idea is because you can't control the mic to mouth distance... you're limited by what you want from the image... the point of a boom pole is two-fold... the independence of the mic allows it to be placed close to the mouth and at the best angle (or place within the hidden space... sometimes booming from below will work better then above).
Also keep in mind that sound is subjective. You can get sound with a shotgun at distance that is acceptable for one use and not another. If you're shooting a drama then that mic better be as close as possible... if you're comparing the built-in mic with a cam-mounted shotgun for something like run 'n gun... then you'll still be surprised at how good the 4073a will sound with things that would normally be considered too far away.
