ptalsky said:Short answer, no. Longer answer, possibly. You can try the noise reduciton filters, but that may effect your dialogue in a bad way. You may also be able to play with EQ to reduce the effect, but basically, this is one of the reasons someone long ago invented ADR. Next time, blimp and windsock. ;-)
Phil
sbryan said:Agreed, sir.
I did use a file I called goodwind.wav as my noise reduction profile, and then put that up against the harsh wind clips. Yes, it did make the dialogue sound metallic, but it's better than having no dialogue.
4.
Noiz2 said:NO!
You can't do that! To have any chance of it working you have to get the noise sample from your tracks. Your probably better off with EQ than NR but??
SK
