A few Queries on aspect ratios.
When using the squeeze mode on the dvx100e does the cam insert line23 wide screen data {data used to switch the arc settings of the display device} onto the tape?
How much of the CCD is being used in this mode?
Will I not get similar results by using the letterbox mode on my DVX100 to monitor my 16:9 frame then vertically stretch the frame past the letterbox in post or during capture to create anamorphic footage which displays correctly when edited in 16:9 viewing on a 16:9 pal monitor?
I realise that I lose about 25% resolution because in letterbox mode about 25% of the CCD is being masked but surely this is still the case when using the squeeze mode on the DVX100E as the new model still uses 4:3 CCD’s?
Please correct me if I’m wrong cause this is all guess work!
Many thanks and happy New Year!
