35mm vs 16mm
hmfilmer
what are the requirement to rent a 35mm camera and what needs to be done when you get the film put on a hard drive? vs 16mm film put on hard drive. do you still need to do like color correction on 16mm and what does color correction do?
do you put a filter on the camera to do collor correction?
thanks
-matt
Don't know the requirements to rent a 35mm camera, that would all depend on the rental house in your area, so you should talk to them.
You transfer the film in the same way you would do it with 16mm, with a telecine, which can be expensive.
Color correction can be done during the transfer, many times referred to as a "supervised" transfer, or you can do it in post with a program like Final Cut Pro.
You are correct, a certain amount of color correction can be done in camera with filters, but unless you are using a zoom lens and a zoom lens only, each different lens you put on the camera when you shoot has a certain color cast. It can be very slight, but it will be noticeable when you cut one angle shot with one lens with another angle shot with another. The other need for color correction has to do with all the uncontrollable in shooting a movie. Maybe you couldn't balance the light just right in one scene. Or maybe there was that florescent light that you could not get out of the scene, or there was a bit of daylight sneaking into that scene shot with tungsten film and no 85 filter. There are all kinds of reasons the color from shot to shot may be a bit off. That is where a good colorist can make all the difference in the film transfer (telecine) stage of production.
Hope that helps,
-Tim
thanks timmyjoe
that explain alot. I want to get into film camera and would like to know how to correctly use them, now i am wondering what is the best way for me to do that? is film school the only way to learn how to correctly use a film camera or getting job for a rent house or telecine company? anyone know what is a realistic best way to do this? i would like to learn to use 8mm 16mm and 35mm cameras.
