25pa final cut capture settings?
Raoul
Hi All,
just captured my first F6 25pa (Pal) footage and it looks a bit strange, blurred, out of focus and the contures aren't clear, they are kind of flickering.
Not sure whether this is cause I shot it out of focus ( the focus numbers seemded right, the shots are all between 5- 15 metres distance no CU's) and did something else wrong or if I have to use some special settings in my preferences and this bad result is normal.
I found a posting on the board with this link that has a screen shot of the audio video preferences. It says to use for NTSC:
Sequence Preset: DV NTSC 48 kHz - 23.98
capture preset: DV NTSC 48 kHz Advanced (2:3:3:2) Pulldown Removal
Device Control Preset: FireWire NTSC NDF
Well, I am in PAL land and can find neither the equivalent option for pal nor these NTSC settings in my final cut preferences. I ve got final cut 3, is that the reason? Do i need fc4?
Or does anyone have any advice, experienced sth similar?
summary: I shot F6, 25p, PAL, manuel iris, 1/50 shutterspeed,
ND 1/8 and 1/64
Thanks a lot!
I'll be shooting tomorrow again, so any quick responses are appreciated...
Raoul :)
Re: 25pa final cut capture settings?
Check your footage on a monitor or TV directly playing back from the camera to check the quality. That will answer the original question.
I think you'll need FCP 4 (now 4.5) to do some alternate capturing. Certainly for those of us using advanced pulldown.
In your case since 25p is recorded at 50i I would assume you could just capture it with normal PAL settings since there's no time shifting as there is going from 24 -> 60 -> 24.
Raoul,
Have you set both your sequence and your clips Field dominance to none?
If not, you have to. Control + Click on the clip or sequence, then select item properties and then set the field dominance to none.
I haven't really captured any 25p on FCP 3, so I don't really know if that is the problem. Just try that.
All the best
Fidel.
Hi Scott and Fidel,
thanks for your posts!
I will try what you suggest. I played it on a standard TV monitor (50i), it doesn't look like out of focus but there is this strong flickering...
Now I read in the manual that with F6 the V-detail frequency is set to thin, which means that only in an progressive environment the picture will be displayed properly, by selecting thin or mid as the item's setting.
So does this mean that final cut 3 at least if captured normally, is not a progressive environment and therefore flickering occurs on the horizontal lines and on the diagonal lines near the horizontal?
Also I used the letterbox setting and the top horizontal black line is also flickering or doesn't look 100 % 'stable', also on the cameras lcd. once captured normally into fc3 it is stable. the shots are tripos shots, especially once something moves through the frame it just doesn't seem very clear in it's contures, they are flickering a lot...
otherwise, the focus distance was quite big, 5-15 metres with numbers like 70-99, it was so bright that i had to use nd 1/8 and even sometimes 1/64, the biggest aperture was 6.8, most of the time i used f 11 or even f 16, so in theory the dof should be huge and i am not usually clumsy with the focusing at all...
Barry, if you read this post, please let me know what you think about this, you seem to be the one that knows this stuff so well!
i am gonna testshoot now with thin and thick detail frequencies and see if that's the point.
is it me being clumsy? using the camera wromg? is it display, capture, progressive environment stuff or is it the camera itself that is defect?
any further advice, comments are very welcome!
thanks,
Raoul ???
I have no experience with FCP so I can't say what may or may not be an FCP issue.
24P/25P with THIN or MID line detail WILL flicker on an interlaced television. Shouldn't flicker on a computer monitor, but will flicker on a TV. What you described about the letterbox line flickering is exactly the interlaced flicker issue. Doesn't sound like you have anything necessarily out of order with your system, just that you shot too high-res for your TV.
Thanks Barry!
I went to a friends house who's got the dvx as well. Watched the footage on his monitor and imported into final cut 2 (!).
He thought it looked all fine, in focus and the flickering that was there, well partly it's the television way/res of displaying the image and and the other reason is probably the thin v detail.
I am glad i used it though, cause i 'm thinking of putting the finished piece on film.
It's so cool that this forum exists!
it's a great and quick help,
Raoul
