25fps on a NTSC/US HVX then into PAL sequence?
Eric H
I am going to use the frame rate hack to shoot 25 fps on the NTSC version of the HVX.....can I just lay this into a PAL sequence in FCP and viola!?
Eric
I've been playing with this on the most-recent firmware upgrade, and the answer appears to be a fairly resounding "no".
I don't know what's changed, but on the 4.05 firmware the 25fps setting appears to image and record 50fps (when in "over 60" mode, which is the only way you'll get sound recorded).
Not only that, but when I toggle over to the thumbnail screen, it's all glitchy and bugged. I have to power down and power back up (and not in a 25fps scene file!) for it to restore to normal.
Even so, I persevered and put that file through Raylight to strip out the duplicate frames; it yielded a 49.967fps file. Not bad, not quite exactly right but not bad. But when I put it on a Vegas 50.000 fps timeline, there was a tad of frame blending going on throughout to convert 49.967 to 50.000.
So, in short, it's a whole lotta trouble and doesn't appear to successfully work.
Something's changed; it seemed to work better on the first version of the firmware. At least one thing I can point to that's changed: it now says "frame rate: 25fps" in the menu, whereas on the first version of the firmware it listed value 15 as "24 fps". (so, before, both 14 & 15 would display as "24 fps", now 14 = 24 fps, and 15 = 25 fps).
